domsaleo
2011 ram 1500 5.7
So I recently replaced my MDS lifters with non-MDS, replaced the oil pump with melling high volume oil pump, and installed an MMX NSR NTR camshaft. I also switched to a slighty thicker M1 5w-30 oil.
(MDS delete purchased through moes performance.)
Cold start: 80+ psi
Driving operating temp: 65+ psi
Idle operating temp: ~24 psi
I feel like the idle pressure is way low considering the pump. I know the truck idles pretty damn low as it is, but without being able to adjust the idle at all I am worried that I could run into the same lifter issue down the road. Any ideas? Thanks
Cold start: 80+ psi
