Luyed LED in Reverse LIghts- FAIL! Bulb out message.
NETim
Nebraska
5.7L
I've seen Luyed's praised here and elsewhere as compatible with the Canbus system on the Rams.
Unfortunately, I get the "Bulb Out" message with them. Getting it now with the original incans installed now too. Lucky me!
Both bulbs illuminate though.
Is there anyway to kick on the reverse lights on these things other than starting it up and popping it into reverse? I'm not wild about leaving it in reverse with the parking brake on.
Is there any other brand out there that folks have had success with on the Rams?
And no, I'm not interested in hacking up the wiring harness to get brighter reverse lights. It's not that important to me.
I'll try dropping the Luyeds in my wife's Fusion and see if they work there.
Thanks!!
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
this just reverse LED's in tails?
rod from md
northeast maryland
i had the same issue...i set mine to LED w alpha< and after the second try it stuck. also was confused w the inability to get them lit by myself...gave up and had my neighbor come over to put it in reverse
NETim
NETim
Nebraska
5.7L
Maybe I need to finally get Alfa up and running. Is it selective with the LED setting, as in, the reverse lights only can be set to LED mode or is it the whole shebang?
Practically each bulb is selectable as LED
NJMOPAR
Older and faster
ELizabeth, NJ
+1 on the Auxito bulbs.
Turn key to run, put truck in reverse with parking brake on.
No need to start the truck.
NETim
NETim
Nebraska
5.7L
Thanks for the input!!
I installed the Luyeds in the wife's Fusion and they light up with the light of a 1000 suns. No error messages either. The Fusion reverse lights have reflectors, so they really get with the intensity.
I will give the Auxitos a whirl.
NETim
NETim
Nebraska
5.7L
The 8 speeds with the rotary selector knob won't go out of park without starting the engine.
Elevated 2013
Huntley, IL
Back up to a window or the garage door at night and you should see them that way.
NETim
NETim
Nebraska
5.7L
Can you shut it off in reverse then?
Sometimes technology isn't always an advancement.
The technology is so "advanced" that when you shutdown, the rig automagically shifts to park.
LarryA
Seattle
Sorry to hear that - I don't have a solution, I know I love the Luyed reverse lights in my '17, lights up the drive way like I have headlights back there! I replaced the cargo lights as well and they are great.
Hopefully you can find a brand that works with no errors.
Side note - wifes BMW hated all LED lights, any thing other than stock caused the computer to be seriously pissed off... :)
Yazen
Columbia Missouri
Kmiko
