Sharkiesha
Hey all, I'm just trying to get parts together for a transmission swap I'm doing and just had a question on how the crank trigger works for a manual magnum engine. I need to get a new flywheel for this swap and before I go tearing everything apart I was seeing if anyone knew how the crank trigger works with a flywheel. One of the flywheels I was looking at says it doesn't work with a reluctor wheel, it's the McLeod 464102 and I just wanna see if anyone has a 130 tooth flywheel recommendation or if the crank sensor is triggered by something on the flywheel itself. Thanks!
