McGaughys or DJM control arms
B3N01ST
Hi, not new but never really post. I just got an 03 single cab ram and would like to do a mild drop. I’ve done some research and it’s between McGaughys spindle kit and DJM control arm kit. Any insight would be greatly appreciated.
Max1329
5.7 Magnum hemi
I’d go with the spindles don’t need to worry yourself with geometry
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I have used the McGaughys spindles for over 10 years and is my preference. One thing to consider is what rim being used. I first ran ss/t 17x9 rims and the bottom ball joint stud will need to be trimmed (cut) for clearance. Knock the steel bump stop cup off and replace with a Timbren (140-65) bump. Shim the bump to keep the tire from rubbing the inner fender. Look at Timbren spec chart and see if any might fit your needs better. And if you want be a different, look at Viking spec sheet and put together a coil over package. Of course they don't make a kit for our beloved rams but you can piece one together.
Lowered5Speed
Orange County, CA
I have the DJM 3" arms and I'm pretty happy with them. You do have to trim the inner tie rod to get the toe back in.20190625_163138.jpg
