2018RMTRCK
I’m doing a mds delete on my truck, I’ve got a kit picked out from Moe’s performance. I can’t seem to get an answer from them about how I get the tune for the cam. Any info would be appreciated
I started doing that a week after I bought the truck. You are correct it does become second nature after a while. Sadly I’ve developed the lifter tick, it’s bad enough I can hear it at any speed now. I’d love to put the money towards other things on the truck but that’s not an option right now.What ^^^ said!
Put it in 8 manually and you're in MDS-Off-Mode.
It does come second nature after a short while.
I've been doing it for 4+ years on my Ram and it's an involuntary action now like blinking...lol.
Unless you have an issue that requires you to do surgery on your engine, put that mod cash towards something else perhaps.
This. Been doing it since I got the truck, mainly because with the hilly terrain around here it never stays on for more than 30 seconds.MDS delete is right at your fingertips. Just activate your ERS, set it at 8, and forget it. You have to do that every time you get in the truck, but it takes like 2 seconds.
I can actually hear mine when MDS kicks in. There is sort of an almost sub-audible low-growling noise coming from the engine, and I can feel a difference in the gas pedal.I have a 2021 pw and I don't notice any difference when it is on or off. The only way I even know it has kicked on is the eco light in the instrument cluster and I can turn that off if I want.
Same. And I also notice a delay to when it turns off. Like I'll be pressing the gas pedal down, more....a little more....more....finally it turns off, drops a gear and takes off.I can actually hear mine when MDS kicks in. There is sort of an almost sub-audible low-growling noise coming from the engine, and I can feel a difference in the gas pedal.
I just engage my ERS. I think doing either has the same effect.Same. And I also notice a delay to when it turns off. Like I'll be pressing the gas pedal down, more....a little more....more....finally it turns off, drops a gear and takes off.
I don't like it. I drive in tow/haul always.
Had a 2017, never noticed it. Had a 2019, noticed a growl like you’re describing. Currently have a 2022, don’t notice it.I can actually hear mine when MDS kicks in. There is sort of an almost sub-audible low-growling noise coming from the engine, and I can feel a difference in the gas pedal.
It's much more pronounced on the 6.4's. Though I did notice it on my last to 2013 and 2017 5.7 as well, just not as much. I still ran those trucks in tow/haul most of the time.Had a 2017, never noticed it. Had a 2019, noticed a growl like you’re describing. Currently have a 2022, don’t notice it.
I've read that, but not on mine. I've had it in T/H and when I reach about 65 MPH it shifts into 8th. I was just experimenting and that was without a trailer in tow, so I don't know if the system can tell that or not.Running in tow/haul prevents shifting in 8th gear. You're always running at higher revs in tow/haul.
I'll assume that RAM does this to try to squeeze a tiny bit of extra mileage out of the truck for that CAFE BS. If I wanted a 4-cyl truck, I'd have bought a 4-cyl truck. I think someone told me that the 2023 model year is the last one that Toyota is offering the 6-cyl in their Tundra/SR5/whatever, and that next year it's only a 4-cyl that you can get.I've never experienced that on either of my 1500's or my current 2500. Not even while towing my RV, I've seen it go in to 8th on numerous occasions...not often, but it will sometimes.
OK, I tried it again today. I put it in Tow/Haul and it was in 7th gear. I accelerated up to 65 and it jumped up to 8th, so it will go into 8th in T/H mode. Again, no trailer.I've read that, but not on mine. I've had it in T/H and when I reach about 65 MPH it shifts into 8th. I was just experimenting and that was without a trailer in tow, so I don't know if the system can tell that or not.
