Member Tags
MADDOG
Living in a Firepit
6.4L HEMI
Just a notice to you all that forum Management is working diligently to deploy Supporting Member & Military Member tags.
This is a long and tedious process and, as you can see, progress has been made.
Rest assured that the tags will be assigned as quickly as possible.
MADDOG
MADDOG
Living in a Firepit
6.4L HEMI
Yup, we are...haven't you noticed?
They are not all up yet but Bryan's working on it.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
So what's the process to get a Mil tag?
MADDOG
MADDOG
Living in a Firepit
6.4L HEMI
The member tags issue has been fully sorted.
If you are a Supporting Member & a Military Member you should now have both tags added to your profile and visible underneath your avatar.
quietpeen
2021 TRX
Hellcat
If not let me Know and I can add the military tag to your profile if you are already a supporting member
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I used to have senior member that seems to have gotten lost in the shuffle becoming a supporting member. Are those two tags either one or the other but not both?
MADDOG
MADDOG
Living in a Firepit
6.4L HEMI
There is no "Senior Member" tag.
The Senior Member logo under your avatar comes from your info.
Click on your User Name at the top right of the forum. Then scroll down to the block named Custom Title right below your avatar. You can enter any descriptor there you want.
Shaggy
Administrator/Owner
Administrator Moderator
Is it just me, or is your Miltiary banner text messed up? It starts off great, then a few seconds into the page load, it gets all messed up?
Shaggy
Administrator/Owner
The text gets removed when you become a supporting member. I might just add that back in as the banners look weird so close to the username. Not enough space between them for my liking.
Edit: I put it back in.
Ramm5.7
So Cal
Thank you Shaggy
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Happens all the time. Or I notice it with mine at least.
Ramm5.7
So Cal
Thanks for the info!
Thats weird cuz Im pretty sure I never typed that in, I wouldnt be so bold as to give myself a longterm "senior" title and DEFINITELY wouldnt advertise Im close to senile...lol
MADDOG
MADDOG
Living in a Firepit
6.4L HEMI
Every once in a while I notice some font alignment issues on all the tags. They start off ok but then look like they are migrating into the sidebar between the tag area and the post message box.
MADDOG
MADDOG
Living in a Firepit
6.4L HEMI
Either way it's too late. :D
The system assigned that designation. Not sure why it didn't survive the tag update. I had typed mine in some time ago.
