Members who had a cam fail, which lifter number??
Which Lifter Number Failed?
  • Total voters
    14
I'm just trying to find out if there is any pattern to which lifter/cylinder number failed with this cam issue. If you don't know just punt the question please. For those of you who had a cam/lifter fail only, which lifter number was the culprit?
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
For my shop most seem to be the driver side, either 5 or 7. That being said we do see them on pretty much every cylinder as well.
Are you saying that both MDS and non-MDS cylinders have had failures? Is the same MDS lifter used for all cylinders, even the non MDS cylinders?
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
For mine is Was #6 Intake lifter and signs of beginning failure on 4-5-7 oh beacause mine is a HD it is NON MDS
And no non MDS Lifters are different only 1-4-6-7 are mds lifters
HEMIMANN
Minneapolis, MN
Thanks - so both types of lifters are experiencing roller and cam failures?
bigrob713
GA
hemi 6.4
Number 6 exhaust lifter and cam lobe. Number 4 intake and exhaust lifters had "latch" turned.
There was no noise until number 6 intake pushrod bent. The only indication leading up to this was an intermittent misfire code for cylinder 6.
Brandon-w
Yukon
2015 Ram 1500
What oil did you run, and what was your OCI?
Oci?? I was running royal purp 5w30 for the longest time. Went to penz ultra platinum and k&n oil filter. If I wanted to go redline it's like $200 an oil change once I got the oil paid and shipped up here. [emoji52]
Sent from my SM-G981W using Tapatalk
ramffml
ramforum
OCI = Oil Changer Interval
Not sure where you are but you can try https://www.partsource.ca/ they have Redline on sale every so often, I've picked up 2 redline oil changes on sale so far. But yeah that stuff is costly.
Brandon-w
Yukon
2015 Ram 1500
Every 5000 km. Or earlier depending on how much weight I'm towing and how long of runs. I'll have to look into That. I'm in Whitehorse Yukon everything costs a ton to get here for some reason.
Is motul 300v is as expensive in Canada as redline? I thought maybe the French connection would give you a break?
Brandon-w
Yukon
2015 Ram 1500
[emoji1787][emoji1787][emoji1787] French connection! they're basically their own country within a country over there! I can't say I've ever looked at that though.
