MIL's truck has problems. Began with starter making a metallic grinding sound. Checked flex plate, nothing wrong there. Brought starter to Advance. Counter man tested both the old starter and a new one and they appeared identical in performance. But he very kindly gave me a new starter.
Installed it and it worked perfect with no grinding.
Next day drove to store, shut it off, restarted perfect 30 minutes later. Driving home engine died at stop light. Restarted after turning over longer than usual. Two miles later died again. This time no crank at all for 10 attempts although dash lights normal. Called tow truck, tried another 10 attempts, truck finally started and ran perfect for the 5 miles to home.
Re-tightened starter and battery connections. Batteries are 6 month old 1000 CA Interstates, voltage at 12.6. Voltage at starter with key on is 12.4. No CEL but scan comes up with U0141 lost communication to FCM.
The truck has an Edge tune.
Any ideas as to what could be causing the shutdowns?
