Morimoto LED headlights
OnSale
5th Gen Crew
Philadelphia, Pa
txfire
txfire
Appreciate it. I actually did a search and it didn't come up for some reason. Thanks
OnSale
5th Gen Crew
Philadelphia, Pa
Sorry I would have linked to the thread but I was on my phone on Tapatalk and was in a rush and couldn’t figure out how to link to it quick enough, so I suggested the search feature. Odd that it didn’t show up, a simple search of “Morimoto” should have found it. I guess the search feature of whatever forum code this forum uses sucks and isn’t properly coded to search the MySQL database properly.
txfire
txfire
So...I looked at my search history and #1, I spelled it wrong...my ******* fault and #2, I was on a different forum! You're all correct...doing a search with the right name turns up all kinds of posts. Thanks again
OnSale
5th Gen Crew
Philadelphia, Pa
If you are interested in buying a set, TRS has open-box/returned sets for sale for $850 in their clearance section and the “always working” 10% off promo code works on them, as well as their open-box led tail lights for the Ram, also listed in their clearance section.
JoshR104
Actually down at 800 now and the 4th of july 25% off discount is working on them making it only $600.... really tempted to pull the trigger on a pair.
OnSale
5th Gen Crew
Philadelphia, Pa
Wait what? The 4th of July promo codes stopped working July 7th. The only active promo code right now for TRS is the usual 10% off that is year round.
txfire
txfire
What is the 4th sale code? I don't see it anywhere
JoshR104
Its in the screen shot and applies it in the cart so I assume it would still work but didnt try to checkout.
JoshR104
Decided to check to see if it came off and does not appear to remove the discount.
JoshR104
D
I have them in my cart right now....only thing holding me back is that they may be broken. If you read the Disclaimer it sounds kinda sketchy.....
Really want to buy these though....worried about flushing $600 down the toilet on something that will not function properly.
They are sealed with butyl so opening them up isnt really hard I know it says bake them but honestly you can warm that up enough with a hair dryer and pull them apart. I should know because I used butyl to retrofit my current projectors on the truck and just opened it up 4 weeks ago using that method to get a chunk of plastic that somehow got wedged in the front bottom housing that was driving me nuts lol.
BrewCrew
Lake Arrowhead
HEMI 5.7L
Lol i bought them. for less than half the MSRP i couldn't say no.
JoshR104
Post up the issues yours comes with. If I didnt have retrofits id probably be buying a pair also....but want to save for amp steps.
