75sausage
I got a Moroso catch can for my 2009. The part number I got from Bully's was 85472 which was not designed for the Ram (Moroso 85479 is for the 2009+ Rams). I was going to have it exchanged however after test fitting it I was able to make it work. I just had to purchase 3' of additional 1/2" heater hose. Moroso 85472 is made for Hemi engines on other cars it seems (ie: Charger) as it is meant to utilize a stud on the engine itself and comes with 2 brackets designed for 5.7 or 6.1L variants. I used the longer of the two brackets and installed it upside down in the spot designated in the 85479 instructions. This worked so well that I decided to keep the kit.
85472 Instructions
85479 Instructions
85472 Instructions
85479 Instructions
