ALDBE
Truck was parked for some time,drove it to storage last year,went to start it just turns over,new gas,changed fuel pump still wont start,blew air in tank,no start,good spark,Im stumped. 86 d 150,318
Are you certain that new fuel pump is actually running..??
Have you opened the fuel line under the hood and seen fuel pour out of it?
That's still a carbed engine, so I would also look for the boosters once you have verified the fuel pump is runningjust did that while ago,no fuel comming out,going to put electric pump on hose and see if it pumps fuel out from tank
no fuel comming out with new fuel pump installed,tried electric pump on line and it pumps fuel,spin motor with new fuel pump on motor and no fuel being pumped,pump was installed properly on cam,???Has it been sitting with the carb full of fuel , that turned to varnish ?
