mdifilippo
I have waded through the majority of these posts and I searched the forums but had no luck with my question.
which is, those with the Active Grill Shutters how do you mount a light bar or "neon" lights in the grill? are the shutters in the way? is it easy to access once you remove the cover over the radiator?
*edit*
Bump???????
It really just depends on how handy you want to get and how much you are willing to drill into the truck. The shutters could be in the way depending on the bar setup you plan to do. The harder part is mounting them as you'd have to fabricate a bracket to either the upper cross bar that the grill attaches to, or below by the bumper.
For my setup I mounted directly to my grill but in order to have room for the lightbar I had to remove one of the plastic "diverters" that goes between the grill and the shutters. It really seems like most people with the shutters stay away from mounting behind the grill.
