Went to do a transmission fluids exchange today as well as filters due to the delayed shifting issue that occurs every now and again. Had all the parts and tools ready to go, and the "stickies" trans flush procedure. If you are familiar with the procedure you know how much fluid should be coming out of the hose and into the bucket. My coworker just did this on his Silverado and said the 5 gal bucket fills up real quick. Well at 118k and no prior transmission service documented the filters must have been shot because I only got a trickle out of the hose when I should have gotten a steady stream of ATF out of it. After I got the new filters in it, everything was good to go, but I did have to drop the pan with 6 quarts in it because of this issue.
That's all I have really, just wanted to share my findings. So with that being said, the job was not at all too difficult and I suggest to anyone with more than 100k on the trans to get it done!
