My update on the 32 gallon fuel tank re-calibration / re-programming!
TSR6
This fuel tank re-calibration was a part of the auto-park update for the trucks that have the 32 gallon tanks.
The issue was that some year trucks were programmed to where the 32 gallon tank would read as if it was a 26 gallon tank. It was a mild annoyance, because the low-fuel warning really meant you had a LOT of fuel left in the tank.
This update did help!
chrisbh17
From all the forum posts Ive read on the net, it looks like it was ALL years that never really got "good" 32 gallon programming. At least they finally fixed it.....now that 4th gens are "old".
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
You have me nervous, I had my update done last week and I drove around all day yesterday with the gas light on... The gas station will be my first stop when I head out today!
T
TSR6
If you have a 32 gallon tank and the old programming you're probably more than fine - fill it up and it'll probably only take 26-27 gallons lol
If you have the new programming, you'll probably put 29-30 in if you're at the Low Fuel warning.
This was done along with the AutoPark recall (U05)
ScottFL
HEMI 5.7
So the truck was definitely acting differently even though I checked my dealer receipt and had the cruise control recall done but nothing about AutoPark.
Since I have had the truck since new when it got to about 30 miles range it would dash out ''---'' and I could put 26 gallons or so into it. Today it went to 20 range and I put in 28, and still had about 70 miles of actual range left (figuring 17.5 MPG). I guess when I am going home after work tonight I will open my door and see if my truck gets pissed and goes into park.
T
TSR6
The cruise control recall is completely separate from the auto-park recall - the autopark recall is a 3 hour reprogramming job.
Roy
Manhattan,Ks
2016 Granite Chrystal Laramie 4x4
Not to hi-jack but what is auto park?
armallard
North East Arkansas
2017 SLT CC 4X4
I have no idea what either are I just came from a gmc to a Dodge 17' Ram I'm tuned in on this thread to see what the recall is for and if my truck is affected.
Ratket
Arizona-
So I took my truck in .. complained to the service writer about my low fuel light coming on at 1/4 tank and still having 6 plus gallons of fuel left... they did the recall that was pending for the auto park and said they did something with the fuel tank... I didn’t believe them and figured they didn’t address the fuel gauge issue... but we got the truck down under 1/8 tank and still no low fuel light... as it began to get closer to E - finally a low fuel light... headed to go fuel it up and it took around 28-29 gallons.... So I don’t know exactly what they did but it fixed it.
b-rock
US
If you read the attached Autopark recall excerpt it mentions addressing the accuracy of the fuel gauge.250ff502bea62f55b9f5f88c114ae1c1.jpg
2017 RAM 1500 CC, LoneStar, Black Pearl
Ratket
Arizona-
Mine is a 2018- not sure if it makes a difference
mcaligiuri
2016 ram 1500 express crew cab
Mines a 2016 I have the 32 gallon tank but never got this letter. Wonder why
T
TSR6
It just recalibrated the fuel tank sensor and the sending unit to more accurately gauge the fuel that's actually in the tank. Glad you had the same reaction I did - it's nice to actually be comfortable to use the 32 gallon tank as if it actually holds 32 gallons!
T
TSR6
If you are in drive or reverse, and open the door with your seatbelt off with your foot off the brake it automatically puts it in park under a certain speed (less than 1mph). You can kind of cheat it by riding the brake pressure.... or just keep your seat belt on, or door closed.
Reactions: Roy
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
kiloRAM
E. TX
6.4 HEMI
Does this just apply to the rotary shifters and 1500's? My 2500 has the NORMAL column shifter, and as far as I know, autopark has never kicked in for me. It yells at me if I have the door open and put it in gear. Like the rest of you, my truck tells me it is empty with 5-6 gallons still left in the tank. I really want to get that fixed.
JPT
NY
2015 Big Horn
Yes, it is rotary shifter models, and only those that were equipped with the autopark functionality that wasn't enabled (it is because of the electronic shifter accidentally or failing to go into park, causing injuries/deaths). They simply are turning on a software controller for hardware that was factory installed but on enabled.
What gets me is, this clearly fixes an issue that all 32 gallon equipped 4th Gen Rams have, but since they only coupled it with the autopark recall, only a relatively small number of Rams will get this fix...
I am convinced they will never offer it on it's own because it isn't a safety issue, and they don't want to pay the shop time. But, what I do not get is, If this is the case, why didn't they couple it with every recall that comes up (cruise control recall), since these will already be in the shop.
BWL
Embrace the skeptisism
BC Canada
They've recently added the autopark recall to the column shift trucks. My 2011 shows it pending, but parts not available yet. Found out when I took it in for the fuel tank recall (added a strap ).
TXCOMT
Well, since I'm taking my '16 Reb back in for intermittent cruise control and rear camera function, I'll try to add this to the list...wonder what the SA will say about that?
TXCOMT
Fryekenn
