Need Help and Advice
DavidJR
Carrollton, Georgia
Hemi V8 5.7
I'm a new truck owner with limited mechanical and electrical experience. My 2013 Ram 1500 is leaking and splashed some sort of liquid all over my engine and has a pee odor, any suggestions before taking it to a mechanic?
kmrtnsn
Ventura
Sure you don't have a rodent infestation problem? No idea where the fluid is originating from? Narrow it down a bit.
D
DavidJR
Carrollton, Georgia
Hemi V8 5.7
Just went out and checked again, I tried to locate where the leak is coming from. But I wasn't able to find it, also its less of a pee smell and more of a fishy smell. Hopefully the photos give a little more detail, lastly i don't believe that it is a rodent problem.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Front diff breather tube? Gear oil has an awful smell and the breather comes up around there as well. Well, on my 2011 it does.
D
DavidJR
Carrollton, Georgia
Hemi V8 5.7
I just took the truck over to the mechanic and was told that I need a new water pump. Only other question I have is how much should I be charged for something like that?
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Look at the hood padding. Open the hood and look up. Thats a good area for animals to nest. Warm and dry. Most people remove it all together because its supposed to be a fire shield but not a very good one
Hemi water pump is somewhat of a PITA, I can see a lot of shops asking 350+ just for labor. If you are familiar with it I bet it takes 2 solid hours, but I can easily see 3-4 hours for average shops these days.
Just googled price this is what trusturmaech says... Totally nailed the price range imo.
Average Dealer price
$429 to 1020
Average Shop price
$312 to 727
It is however a very average DYI job, you can do this if you have the right tools. Nothing too radical, just have to remove a couple pully's, hoses, and belts and ops the fan blades/shaft.
kmrtnsn
Ventura
Depends on the miles and which kit they go with. Changing the serpentine belt and worn idler pulleys is part of most waterpump replacements these days, $350 is really reasonable if changing all of that too, along with OAT coolant, which of course is more expensive.
why do you need a water pump? whining or over heating? Did the mechanic look at it? How long did he look at it before he said it needs a water pump?
