need help asap please
Justino689
5.9 magnum 360
so today i was testing my 4x4 so i know it works for when it snows and well it broke through the yoke. is their anyway i can take out the short axle so i dont mess it up anymore til i can afford to buy a new yok. pretty much what im asking is can i drive with the short axle piece pulled out. its on the passenger front. its a 97 dodge ram 1500. 5.9 v8
homeguy
Calgary AB
2013 Big Horn
You should be able to. If it's anything like a JK you'll just need to plug the axel tube so oils doesn't leak. If the end of the axel holds on the hub. You'll need to keep that
J
Justino689
5.9 magnum 360
okay . should i drop the front drive line?
MADDOG
Living in a Firepit
6.4L HEMI
You can and I'd recommend it to avoid further damage that could happen if the 4WD was to be inadvertently activated.
homeguy
Calgary AB
2013 Big Horn
I would just to keep it isolated. Don't forget to plug the end of the tube. You'll have lots of oil splashing around in the front diff
J
Justino689
5.9 magnum 360
So this was my quick fix. Forgot to post it. Expandable freeze plug and gasket maker.
J
Justino689
5.9 magnum 360
Not many scrap yards ever have ram 1500 with straight axles. There all independent.
dapepper9
Iowa/Nebraska Border
5.9L V8
I'd send ya mine after I finish a single shaft swap if you're still looking at that point. Hoping to get to it this weekend but that's weather permitting
joshhhh
