Need help guys!
THEBAD1
2003 Sport SLT QC2WD
Ok,
At the end of the season my amp went out. So I just added a new amp and subs and nothing...no sound? The headunit is a Kenwood 516 that is about 2 years old. All the wiring is good, power to everything, sub is turned on ..on the head unit, amp has power but, no sound? Could the RCA cables be bad?
"LOST"
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
That would be the first thing I would check. If the rca cable are good then its not too uncommon for the rca jacks to go out. Had a Kenwood that did the same thing. Trouble shooter for HOURS!!! and then replaced the head unit. Problem solved lol, I had that unit for 3 yrs so it didn't bother me to replace it.
Sent from my ADR6350
rpardo
miami, fl
4.7 l
How did u replace the head unit?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Wat do you mean.?? I replaced the entire head unit with a newer Kenwood unit.......
quietpeen
2021 TRX
Hellcat
this might sound crazy, but did you check the speaker wire connections at the sub? I once though a sub was going bad and when i took it out i found that the connectors were loose and almost falling off. When i tightened them it sounded great again. Maybe one fell off?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
amp may have power, but does have to get signal...without running all new RCA's, get some, pull HU out and run then from HU across seats to the amp, see if its them. If not, pull speaker wires from amp, hook up speakers to known good wokring source, make sure its not a speaker. If amp and speakers work, the HU is the issue.
THEBAD1
THEBAD1
Well, after many hours playing with this.....all the setting on the new amp was set at "O" . After tuning thesetting on the amp all works fine
:suicide:
quietpeen
2021 TRX
Hellcat
good to hear it was just a setting
Graygoose
Oklahoma
Convert, for now.
small
good...cheap, simple fix :D
