Need help wheels spacers or smaller tires
BlownGP
Houston/Baton Rouge
here's an idea..Not sure if it's possible..but what if you had Motosport Tech create some custom wheel adaptors that incorporated the new wheel bolt pattern? If it isn't that far off than you'd be good to go!
Just spit balling lol
That's what I was going to say. If you're going to get spacers. Make them in adaptors.
Although a 20x10 wheels probably has a low offset so they might be pushed out too far.
G
gray8188
tampa, fl
Won't work unfortunately. I asked a local place that makes them. Something about the hub on the wheel is to small. The wheel is a 5x5 I need a 5x5.5. If for example our trucks took a 5x5 and the wheels were 5x5.5 then they could make an adapter. They cant make one to go with a smaller hub only bigger.
BlownGP
Houston/Baton Rouge
Most 5x5 hubs are 78.3. Ours is 77.8.
According to Fuel site those wheels should have a 78.10mm bore D538 SPECS
so, I see what there saying but it's really splitting hairs. They technically don't have to be hub centric for the rims. Mine aren't.
