Need help
brsndontierney
Need some pointer on how to get my exhaust manifold off my 2004 Dodge Ram , bolts are rusted pretty bad and I'm scared of breaking them off in the block . Any ideas , I been spraying then with pb blast for a week now .
Pull Ya
Cedar Creek, Tx
This stuff works better than anything you can buy--cheaper too
Jay
How to make your own penetrating oil
Rust penetrant manufacturers are constantly working to improve their products. The latest formulations work better than previous brews. So if you’re still using a 10-year-old can of penetrant, you might want to upgrade to the latest formulas from Liquid Wrench or the Specialist Rust Release Penetrant from WD-40.
As great as those new products are, occasionally you can get by with a home brew—a 50/50 mixture of acetone and automatic transmission fluid. It has a strong smell and is far more flammable than commercial products, so make sure you use it outdoors and away from flames. It doesn’t work as fast as the commercial products, but if you need rust penetrant in a hurry, it will work.
sbarron
Wasilla, Alaska
Apply heat and gentle impact of you can get the room. If not, patience (!!!), penetrating oil, and a little tug on a breaker bar every now and then. Make sure you are using a 6pt rather than 12pt socket.
