need opinions quickly!
the codes
Houston, Tx
Magnum 5.2
yes or no to mounting the amp here? think I'll run into heat issues?
Tapatalk Addict
Mad Cow
Anchorage, AK
Cummins 6.7
You would have to take out your seat to adjust anything on the amp. Do you have room under the driver seat to mount it?
the codes
the codes
Houston, Tx
Magnum 5.2
ended up with under the driver seat. I agree that is the best place because there's already a slit in the carpet to run wires under the carpet to the door sill. thanks guys! almost done
Tapatalk Addict
WhiteExpress
Midland, TX
Run down to an auto parts store and get some Dynomat for that cab wall. You'd be amazed what a difference even a couple pieces makes.
(I did 2 layers over everything, WOW!)
the codes
the codes
Houston, Tx
Magnum 5.2
yeah I think I will be doing that sometime, thanks for the suggestion
Tapatalk Addict
MADDOG
Living in a Firepit
6.4L HEMI
I was gonna suggest you move it but I see ya already did. Good choice!
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have one under each of my front seats, plenty of room.
the codes
the codes
Houston, Tx
Magnum 5.2
yeah it ended up fitting really well down there and running the wiring through that slit made it easy.
Tapatalk Addict
