need Wheel cylinder links/brake shoe links/pins 98 ram
DMK73
chippewa falls wisconsin usa
1998 2018 1500 Sport Hydro Blue crew cab
I need wheel cylinder links for my 1998 dodge ram slt larmie 1500 rear drums. part #s and where to buy. tks
Okiespaniel
Work, Shop, Computer
magnum, 5.9
You can't find them? Strange.
I can't remember the last year, but I believe in 98 the Delco Moraine Brakes were still used. This means that Chevy Pickup truck stuff interchanges.
Try looking on RockAuto.
The links might be scavenged off a used truck.
D
DMK73
I found them on Amazon they are H1421-2 from Carlson brakes co. I had to buy 3 different sets to find the right one. Nobody lists truck application. Even the local parts stores don't have this info. New wheel cylinders do not come with these links in the box anymore. My area junkyards have all closed or the few that are left only handle newer year trucks. Nice to know that Chevy parts do interchange. Thanks for the reply.
sgopus
5.9 l 24V Diesel
I replaced my rear wheel cylinders for the larger GMC wheel cylinder for a 3/4 ton truck, gives better braking power and less pedal pressure required. NAPA part number UP 37337
D
DMK73
Thanks for the info. I will ck Napa for the part. What year GMC 3/4 ton is that?
sgopus
5.9 l 24V Diesel
Doesnt matter use the part number it fits perfectly for my 98 dodge ram 2500 direct replacement will work for your truck as well
