Need wiring help 2011 ram
Jack Watters
My 11 ram has a quad headlights with factory drl, I want to put led pods where the drl/high beam is. How do I wire it up? If I just use a aftermarket switch, what can I do to eliminate bulb out message?
bigred90gt
It seems to me the effort required to install an LED pod in place of the high beam, which would require baking open the headlights, cutting out the reflector and retrofitting in the pod, is a ton of wasted effort. I would think you would be better off installing some plug and play LED bulbs. It will be much cheaper, nothing additional to wire, and wont require butchering your headlight housings. I dont know which brands or models, but there are plenty out there that work with the reduced voltage of DRL.
