No. You cannot stack a 2” leveling spacer above those. Your 6” lift uses a 5” spacer above the current strut. You would have been better off with leveling coilovers like mine. That would have put you at 7-7.5” of front lift. You cannot gain that much lift with those 4-6” lift coilovers. You are already at 6” front lift
Sorry, I'm still a bit confused. I just remeasured and the current oem strut in there and it is 19.5" and 24.5" with the 5" spacer. The 883-06-073 CO's I have are 26.5". So that should raise my front 2", correct? That may not quite be level, but close. With the 883-06-080 that you have, they're 22.5", which would be 27.5" with the 5" spacer.
I'm really just looking for 2 more inches upfront as a possibility. The option to adjust the coilovers 2 inches down, back to my current height, would be ideal.
Why would a 2 inch spacer ontop of the 883-06-073 not work?
Sorry if I'm being dense, something just isn't clicking for me.
My current height from ground to bottom of my bushwhacker fender flares is about 43" in front
