New engine... knock!
J-DOGG
Ca
97 1500 2wd 5.2 - Purchased long block came w/ new oil pump and felpro gasket set. Got Hughes plenum kit, new distributor set and wires. Cleaned everything up and swapped the motor, fired right up and set fuel sync with my snap on brick scanner. Runs and revs no problem, go for test drive and I start to get a light knock, starts to get louder and let off the gas it gets super loud and slowly goes away sound clip:
https://photos.app.goo.gl/sX2FRcink9CHiuiz5
Fuel sync set, no misfire codes, good oil pressure, pulled valve covers and checked rockers, gone thru anything I could think of. Any suggestions? Thanks for reading!
Fast69Mopar
As long as this thing has oil pressure it sounds like a rod bearing was wiped out or a rod cap is loose.
Who built this motor? Who did you buy it from?
Did they have specific instructions on how to keep the warranty intact during installation like certain procedures or anything like that?
Reactions: Mop
J
J-DOGG
Ca
Also doesn't throw any codes, 0 misfires and normal 02 readings on live data
J
J-DOGG
Ca
Yes the system was primed prior to starting
Fast69Mopar
What did the oil pressure look like once you got it running? Was it normal on the gauge?
Was there a lot of lifter noise or rocker noise when you first started the engine?
After listening to your sound clip that is definitely a rod knock. It sounds like a bearing failed or a rod cap was left loose. I would get in touch with the engine builder and see what they want you to do to the engine before you take anything apart. They will more than likely want pictures of everything for warranty purposes.
Dodge 1500 4X4
Rochester, NY
If you have good oil pressure its possible its a Wrist Pin, Pull spark plug boots one at a time and disconnect the injector wire to see if the noise goes away, that will tell you what cylinder is at fault
J
J-DOGG
Ca
No problems with oil pressure. No rocker noise during first startup.
Contacted the engine supplier today, the guy who handles warranty will call back.
J
J-DOGG
Ca
I was thinking about doing this previously but it's not constant so kind of tough to pull over in traffic and check before it quiets its self
Dodge 1500 4X4
Rochester, NY
How is the flywheel I've had one have hairline cracks and it was flexing making a knock sound, you really need to put a mechanical oil pressure gauge to get a true reading.
Orca
