New Jones Max Flow muffler swap
blackbetty14
blackbetty14
CT
Hemi 5.7 VVT/Etorque
The reasoning for my method is that I don't want to modify the exhaust to void the warranty. Plus mine is lease currently so if I want to convert it back to stock it's super easy and looks like nothing has been done.
I don't believe the stock exhaust is stainless tho. Looks like aluminized steel to me.
TylerB
FL
It is stainless albeit low grade 409.
Thanks for reminding me about these mufflers, gonna be swapping two of these on my truck which will be much easier to swallow then two Magnaflows.
Jerry1984
Meridian, Idaho
Wish I would have known about this a few weeks ago. I built mine for slightly cheaper but this would have been way easier. 20 bucks mini bullet, 25 y pipe and 20 for 2.25 inch piping. Cousin welds so we welded it up and then we clamped it in.
loveracing1988
Clarkston, MI
There isn't a vehicle in production that has came without a stainless exhaust from the factory in years... They don't last more than 3 years in the rust belt unless they are stainless.
blackbetty14
blackbetty14
CT
Well guys i went ahead and finished the install of the exhaust. Basically pulled the muffler out and knotched it out for the stock tail pipe alignment pins. The exhaust is pretty centered, might look alittle off (viewing angle) in the pic but its pretty good. I like them tucked in more than sticking out like stock. The tail pipes can not move or rotate as they are locked in now.
So here are some pics of the knotching of the muffler exits and the end result on the truck.
knotched muffler for alignment pins
This is the inside of the muffler… basically straight through with a y at the back end.
overall its a nice sound, not noticeable at idle (only on cold start) and gets louder… still some resonance kinda in the 1600-1800 range but not as bad as stock I think. She sounds real good above 2K to redline.
Iczer
2014 Dodge Ram Black Express
Got mine installed Sunday and am loving it. Didnt do the notches yet so i'm living with the alignment right now..it's not horrible. I'll have to do that next. Overall I'm more than pleased... $70 well worth it. She gets loud when u get on it and is nice and quiet when cruising.
Thanks for all the info
blackbetty14
blackbetty14
CT
No problem! Glad u like it. I love it... love that cruising isn't annoying but give her gas and she roars!
RamminJammin
Center inlet muffler?
Hey guys Ive been reading the thread and I get installing a 8" pipe and how that plays in ,however, why a center inlet muffler I've look at my 2014 and it seems like a center inlet would have the muffle almost touching the frame. Could you also post some pics of the exhuast installed. And lastly what's up with notching the muffler. I'm looking at installing my own flow master ( personal preference) nice thread on DIY muffler install. A lot of ppl don't reali how easy exhuast work can be and how much you save compared to a local muffler shop.
blackbetty14
blackbetty14
CT
You clearly have not retained what you have "read" then. Most aftermarket mufflers have center inlet and dual outlet... not many options with a single in and dual out. Mufflers are much much smaller than stock and therfore fit with no issues. The exits need to be notched to accept the factory tail pipes as they have alignment tabs welded on to locate the exhaust for a perfect fit. If you dont notch the muffler then you would have to grind the alignment tabs off so the tail pipes fully slide into the muffler. Or you could leave the muffler as is and tail pipes and line it up and hope that the tailpipes don't move around (which they do). So to finish a clean install and not have any worries about the tiPS not staying lined up, u notch the mufflers vs tweeting the stock tailpipes (void warranty) and get it to fit like stock.
RamminJammin
Wow you are so helpful! I'm a complete illiterate *******! I couldn't have survived another day without your expert advice. Thank god there's ppl like you to help special ppl like me! I love online chat and really appreciate dealing with fine gentlemen such as yourself!
blackbetty14
blackbetty14
CT
No reason to get hostle, just made a statement saying it's been covered in the thread before... u would have had no reason to ask a question for it to be reanswered or restated multiple times if u reread the thread to "retain" the information. I could have just told u to reread the thread and give you no answer to your question, but restated it anyways.
If you can't handle the respones on "online forums" then u shouldn't post. Apparently ur very touchy and shouldn't just blast down someone's face when alot is missing in "online chatting" like tone etc. But ur sarcasm is very unwelcomed and would rather you not waste a post in my thread with a nonsense childish response.
