New on this site
PWRWGN
Edmonton
I own a 2008 power wagon. Having electral problems.
I was using it the other day and turned off the engine…all was ok
I went to use it again and nothing. There was no power at all. Checked the battery and the voltage was 12.74 volts. One thing that I did notice was when I removed the negative battery wire, there was a little spark from it, not sure if that is normal. I hooked it back up, turned on the key, seemed everything was normal, fuel pump started and lights came on in the dash. Turned the key to start and nothing again. Everything was dead again.
Has others had the same experience on here? Would certainly like to know what to check.
Thanks
