New to me 2016 Ram 1500....... jump/lurch/bump when stopping?
Micah12
Long Island
I’ve never driven it in tow/haul unless I’m towing my boat, and I still have some pretty violent clunks and lurches when doing so.
I just went to a local mechanic who has worked on my vehicles in the past
He said it may be the "Universal Joints " are bad? There are two
Does this make any sense?
Micah12
Long Island
Update:
So, I've tried everything you guys have suggested, other than greasing the splines on the drive shaft, so I suppose that is my next step.
I tried turning off the MDS by using the gear select and selecting D8, and I tried using the tow/haul mode. I felt no difference either way.... tranny still shifts hard when downshifting and jumps at the 2:1 shift.
I did notice though that my eco light never comes on. Even when in standard D. I didnt know I had one until you guys pointed it out. Read on another forum that in order to see the eco light I need to play with settings and "activate" or something, in order for the light to turn on. So I'll try that. But I also read that the "eco" light doesn't necessarily coincide 100% with the MDS. It's more of a fuel consumption thing. And the light turns on when your above a certain mpg. So just because the light is on doesn't always mean you have dropped to 4 cylinders.
So anyways.... the hunt for the fix is still on, thanks for all the help guys
Bubba,
Curious to see if greasing the splines cured your issue?
ReezyA
Atlanta, Ga
Rezzy,
I am battling for a new drive shaft, which Chrysler is ignoring.
What location did you have your issue resolved?
I can use any help at this point. The bump stop and lurching is awful, new tranny and value body, and tranny re-learn did nothing.
It was at Glendale Chrysler in St. Louis
kdubb88
Peoria, Az
2019 Classic-2wd
5.7L
Hello all. I just spent about 20,000 miles and a year and a half trying to get the dealership to "duplicate the problem". I finally was success full and just before the factory warranty expires. Bad slip joint on the drive shaft. Ram replaced the entire drive shaft and carrier bearing as a whole unit. 56,000 miles on it. Hoping that this shaft is better over the long haul. Right now, no lurching, clunking or bumping. (2019, 5.7L, 8 spd, 1500, Quad Cab, 2WD)
CunningStunt
Abbeville, AL
5.7L Hemi 4X4 Crew White/Chrome
Sometime turning off hill assist has worked for some folks. If it isn't extremely violent it has to due with the way the 8speeds downshift and is not bad
