New truck, transmission issues
kadkins22
WV
I got a 99 with the 360 automatic. It has started shifting really weird. Some times it will shift perfectly other times I have to let off the throttle and others I have to put it in neutral and back into drive for it to shift. No CEL is showing and no burnt smell in the fluid. Fluid looks great .Any ideas?
I've ordered the governor solenoid, transducer, tcc and overdrive solenoid and plan to change all that along with fluid filter and band adjustment. Should this cure it or do I have bigger issues?
Thank you
K
kadkins22
WV
Also noticed it seems to shift better before the transmission warms up but very sporadic
Sent from my SAMSUNG-SM-G890A using Tapatalk
GregS
Monona WI
After installing the new parts you mentioned, did it make a difference?
K
kadkins22
WV
Yes it is shifting a lot better. Only issue now is in traffic conditions at lower speeds (35-45) when I lightly apply throttle it'll jump to about 2k rpm and then drop back down to where it should be. Not sure if that's a separate problem or what
