No low beam
cooler
Hi all. My coworker have 04 Ram 1500 2wheel drive 2 door Hemi. Problem is that on his right side head light is no low beam. High beam works on both lights left and right. New light bulbs but no power on right side low beam. All help taken plz.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Headlight switch sends on/off signal to Instrument Cluster, this signal is then further controlled by the Multi-function Switch to determine High/Low/visual horn status. This signal then is sent to the front Control Module (FCM) which then signals the Integrated Power Module (IPM) to provide 12v power to the headlights. A guess would be bad Multi-Function Switch or corroded IPM. Recommend reviewing the Service Manual for details needed to properly trouble shoot the problem.
C
cooler
Tx. I will check that.
b97ranger
marlborough, ma
Just had that same problem on my 07 2500, brought the truck to a guy I do business with, he reset my TIPM with his scanner no problems since
Sent from my GT-N8013 using Tapatalk
