Not starting no codes
bwilde86
Illinois
Truck isn’t starting and running out of ideas. I bought a new battery since it died in the middle of winter.
Truck cranks and won’t start even with starting fluid so asssuming my issue is spark related
Tried pulling codes and don’t have any codes (possibly from battery dying).
Every time i google it seems to lead to camshaft sensor and crankshaft sensor. Will these throw codes as soon as I try to crank the motor if they are bad?
LoneWolf3574
Grab the FSM from the 3rd Gen DIY section, that will help get you started. https://www.ramforum.com/threads/3rd-gen-parts-manuals-and-2003-2004-service-manuals.6504/
Any of the following may be the cause:
- No Spark
- No fuel
- Faulty Coil
- Water in your fuel
- Faulty fuel pump, relay, or associated wiring
Other possibilities that you may have already taken care of or eliminated:
- Weak battery
- Low or no compression
- Faulty starter
- Corroded/loose battery terminals
- Incorrect plug gap or fouling
LoneWolf3574
Keep us posted on your results after you fix the problem.
