O2 sensors
no name
Socialist Republic of Illinois
Hopefully someone can answer this for me. I had the cel come on. Had someone scan it real quick just to make sure it wasn't anything real major. He said it came back as a low voltage (?) on the o2 sensor. My question is can I have him scan it again to see which o2 sensor it is or do I have to replace all three of them?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Turn your key to off-on position 3 times and the 4 digit code will come-up on the odometer/dash light and hopefully it will give you the number which will tell you which O2 it is. Not sure if it will break it down for you like that but you can look it up easy. my 03 only has 2 of them, one upstream and one down.
txbass06
NE Texas
5.9 Magnum
It should have a description along with the code that'll say "Bank one sensor one" or something like that. Not sure which side bank one or two is but sensor one is the upstream sensor before the cat, and sensor two is the downstream after the cat
Sent from my iPhone 4 using Tapatalk
N
no name
Thanks guys. I will test it out sometime soon hopefully. Worked outside all day today no time left now to do anything but the stuff I have to do.
