Obd2 bypass cable
Formershaker
I’m looking at adding remote unlock to my 2019 1500 tradesman classic that came with the base transponder key with no key fob, and found a way to do it in another post here, and I needed an obd2 bypass cable, I bought one and it came with just the one white connection, but I’ve seen others with the white and green connection, do I need to get a cable that has both on them or am I good with just the one? I haven’t seen anyone explain if there’s a difference and I’ve seen people use both for various things so I’m just a little confused
Atcer2018
Virginia
To the best of my knowledge the single connector bypass cables only connect to the BCM and the two connector cables connect to the BCM and the RF Hub. I would assume you would need the two connector cable as you’ll be programming key fobs in the RF Hub.
I bet @Mpgrimm2 would know the answer to this, let's see if he chimes in
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Depends on what you need to program via AlfaOBD & OBDLink MX BT adapter ... Certain modules need to be accessed via CAN-IHS bus, some via CAN-C bus... Who knows which bus that one uses, but it's definitely not both.
If it was me, I would want one that works with both like the one that @DeereGuy makes (www.Kaodtech.com) since OBDLink MX BT adapter is smart enough to switch over automatically as needed to which ever bus is called for via AlfaOBD.
