OEM push button start kits
Jimmy07
Jimmy07
This?
https://nexelec.com/YAZAKI-7283-6079-30/
Sent from my Nexus 6P using Tapatalk
Yup. I probably came across that before, too, but my eyes were probably wobbling from looking for all the different connectors and matching terminals. The handles will be the last thing I do, since I dread taking the door apart again (already swapped handles once). I’ll probably just bite the bullet and get the 10 minimum.
chrisbh17
I might be interested in some of the extras, or the actual harnesses if you wanted to make more.
Cillys
Virginia
Ha wait guys. I started the thread in hopes of combining all the knowledge gathered over the last few years into a single thread. Lol. I like some harnesses as well [emoji1744]‍[emoji3603]
Btw took these pics of the rfhub today outta my18 5500
Jimmy07
Your last pic is the reason that hub is not keyless enter and go capable. No Provision for the C2 connector.
Cillys
Virginia
It's not mine ... from another truck that I had access too. The rfhub part # was different so I wanted to grab it so ppl know and we can research it too
skuppy069
canada alberta
2018 1500 cc
skuppy069
canada alberta
2018 1500 cc
I’ve started building my harness .
I’m going to build it for the complete setup .
Have most parts on order except the door handles .
Want to make sure the system will work with alpha first before I purchase the door handles
Should have the harness built by the end of the weekend .
Will get hanress in place the following weekend i hope .
Jimmy07
Were you able to find the terminals for the connector that plugs into the door handle?
skuppy069
canada alberta
2018 1500 cc
No I didn’t . I’m going to just cut the plug off and put a molex connector instead
skuppy069
canada alberta
2018 1500 cc
So here is my harness I built
8 hours work etc .
White molex plug for future door Handle
I’m running the handles and antenna wire together into each front door .
Then one antenna in the Centre console and on next to the hub
skuppy069
canada alberta
2018 1500 cc
Some more pics
This the layout kinda Of the truck
The three plugs go up front of the truck and the other stay at the hub
skuppy069
canada alberta
2018 1500 cc
And a messy messy work station lol
I hope this all works in the end
Will try install hanress into truck thru out the week .
All my parts in at the dealer so will pick up tomorrow
Will get all antennas etc installed in the truck and wiring next to existing hub
Then will do the swap in the dealership parking lot Incase i ......up.
skuppy069
canada alberta
2018 1500 cc
Ok. To fully understand here what is it all you built again and what yr truck?
My truck Is a 2018 ram 1500
It’s basically 4 wires to each front door which is two for the antenna and two for the door handle sense
Then two wires for the rear antenna which stays next to the RF Hub
Then two wires for the Centre console antenna
Total of 12 wires .
Basically one big hanress from the hub and then the once past the doors under the way the harness splits off into three sub harnesses for the three front components
Cillys
Virginia
Total of 12 wires .
What antennas in the door?
skuppy069
canada alberta
2018 1500 cc
Yes the factory puts the antennas in the Rear doors but I don’t want to build 6 sub harnesses so I put my door antennas in the front door as I needed to go there for the door handles etc
ROYSZZ4
