Ohms of Alpine speakers
stepbill
Aberdeen, North Carolina
Does anyone know what Ohm speakers the Alpine 9 speaker setup is? I want to replace my 3 dash speakers and the rear door speakers. I was reading on a Ram diesel forum and it appears the older models were like a 2.3 ohm and then way later on in the post someone said that they were ordering 8 ohm speakers. Hope that someone can help!
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
I actually just replaced mine and while they were out I took a reading. I got 2.7 on the three in the dash and 2.5 on the front doors.
The dash replacements were 3.8 and the front doors were 4.6. I ordered the mopar kicker upgrade speakers just to try it out.
RoadRamblerNJ
Mountain City, TN
392 Hemi
When in doubt,
Get the multi meter out.
runamuck
Air Force
dfw
6.7 dsl
as I only have limited knowledge of electronics I am curious that if you replace 2.5 ohm speakers with 3.8 ohms wont you have to turn up the volume to get the same amount of sound out.
ErnieBoling
South East Texas
6.7L Cummins
Yes, my volume is much different with the Kicker aftermarket speakers I installed, but the sound clarity is absolutely amazing.
DanBen
Skaneateles NY
There may be a difference from the reply with the 2014 Ram vs the 2019 Ram speakers? You may want to get your information from a 2019 owner if the speakers have changed over the years - or they may still be the same.
DanBen
Skaneateles NY
tastysuds
Just go get speakers made by Infinity, fit great, sound great, approx. 2ohm speakers. Most people just replace the front dash speakers and that helps alot.
fotomatt1
Lehigh Valley, PA
2019 Laramie Crew Cab - Flame Red
5.7L HEMI
The 3.5" infinitys that fit the dash are 3 ohm. Infinity doesn't make a 2 ohm speaker....after speaking with Crutchfield, no aftermarket manufacturer seems to. The closest were the JBL GX302's, but they don't make them anymore.
