Oil change
Nickxxxr
Near Reading, PA
Dumb question. I changed my oil at 3000 than at 9000 miles. Now at 11235 miles my info says oil change due. How do i remove it? It never came on before because i changed oil before i was suppose to. Now Idk how to remove it. I change my own oil i don't spend 45 bucks at the dealership to do it. Any help please
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk
bigbadram1500
Springfield, IL
I don't know if it's the same for 4th gens, but on the 3rd gens, turn the key to the on position, press the gas pedal 3 times within 10 seconds then turn the key to the off positon.
Nickxxxr
Nickxxxr
Near Reading, PA
All i can do is try. Ill try tomorrow morning. Thank you
Nickxxxr
Nickxxxr
Near Reading, PA
Worked thank you very much
quietpeen
2021 TRX
Hellcat
glad it worked for you
Grubrunner
Just curious why you did your first oil change at 3K then went another 6K before another change?
Nickxxxr
Nickxxxr
Near Reading, PA
Cause i didnt put original oil in it so i don't trust it. It got changed out like a normal oil change. Than i ran extended life oil and filter now so i let it go to 6k. Im picky about my vehicles. I don't trust anyone's work but my own.
Nickxxxr
Nickxxxr
Near Reading, PA
Its due at 15k now
