- Apr 28, 2012
- 23,329
- 45,144
- 2010 Hemi Reg Cab 4x4
- Hemi
Thanks for checking those though...
Why, when I go to Summit Racing to order the RP 20-820 filter for my 2023 Limited 5.7, does it say it doesn’t fit my truck? Has there been some change that further limits clearance or is this just BS? What am I missing?
You are miss using your tv man, if yesterday xfinity race means anything that channel should be on martinsville cup race. No refs to ruin the game like we see in every nfl game this year. I like my sports to use oil filters, just say'n
Cowboys are blowing out rams, they didnt need those two calls one for and one against both on cowboys side in the first two drives, I am over this garbage. And I even have the cowboys on my pick, I just hate ref ruined games even if it is in my favor.
I'd go with a relocation kit that lets you use the older style 3/4-16 thread pitch filters (aka the old style PH8A filters),there's a way better selection of bigger filters in the older 3/4-16 filters.It'll fit ... it's just a tighter fit due to the "oil cooler/heater" that was added~2013? on 5.7 HEMI 1500 reduces the clearance between the engine and cross frame support and to resolve that the engineers came up with an smaller oil filter to resolve that matter, don't know about the 6.4 HEMI in the 2500/3500.
Some folks stated the "larger" factory oil filter, MOPAR 899(Royal Purple 20-820), wouldn't fit due to the added electric power assist steering and the oil cooler/heater compromises to be able to fit it in place ... ? idk.
I have an 2017 HEMI 1500 and in the owners manual has it listed to use the small oil filter MO 339, however, I use the larger filter(s) (Royal Purple 20-820)for peace of mind and it fits ... just a little tighter to put on and take off ... I'm still considering an oil filter relocation kit that'll take the same larger oil filter with no issues, that'll surely be a good upgrade ... just ait decided on what brand/type.
Good luck and happy motoring.
Hard to tell in this pic,but the filters on my Transdapt kit,are a hell'va lot bigger filter then what you can get in the 22mm-1.5 thread pitch filters.
I'm no fan old the pacbrake kit after getting a close up look at one awhile ago,the only advantage it has is the pre-made hoses,but any farm implement shop can build you comparable hoses.
The 90* elbows on the Pacbrake kit reduced the oil pressure on my rig by about 4PSI average. I decided that was too much to give up. There are 4 elbows all told.Yeh, thanks for that. I like the duel oil filter relocation setup that you have ... just a single oil filter will be good for my HEMI, it's just an daily driver with an occasional kick in the ass to blow out the "cobb webbs, lol.
If you have it apart,i'd also take a die grinder to it and round off every sharp corner you can get at with a carbide bit,followed up with a sanding cartridge roll.For the price of the Pacbrake kit,you'd think they'd be able to program the CNC cutter to at least round off the edges of the passagesThe 90* elbows on the Pacbrake kit reduced the oil pressure on my rig by about 4PSI average. I decided that was too much to give up. There are 4 elbows all told.
I'm no fan of the Pacbrake kit after getting a close up look at one awhile ago,the only advantage it has is the pre-made hoses,but any farm implement shop can build you comparable hoses.
Yup they're basically the same as the old style Fram PH8A filters that Ma Mopar and Ford used for years.Beauty of them is you can get a PH8A style filter in the middle of nowhereAre those Royal Purple oil filters your using equivalent to the old school large oil filter(s)?
Subject Product Information Message: Hi, I need some help with oil filters for Ram Hemi engine. This engine is poorly lubricated and sensitive to cam failure. I use Fram Ultra XG, but now Titanium & Endurance were introduced. What's the differences? |
Hello Brian, These are all premium filters but for differences I would look at these things. The Endurance is our most durable oil filter optimized for use with synthetic oil to deliver 99% filtration efficiency. Designed with a heavy-duty shell and metal screen back construction in the fully synthetic filter media and maximum engine protection for 25,000 miles (40,000 kilometers). The Titanium is a high-flow synthetic oil filter featuring premium synthetic blend media for over 99% dirt-trapping efficiency and provide proven protection for up to 20,000 miles (32,000 kilometers). Thank you for contacting Fram |
