HangmanNY
While doing Transmission Service, transfer case, and front differential fluids, I noticed that there’s oil on the back edge of the gas tank. Right in front of the rear differential.
About a year and a half ago I was driving at night and some idiot dropped a 5 gallon bucket of joint compound on a main road . I didn’t have time to swerve because of oncoming traffic.
I was cleaning that crap off from the underside of my truck for quite a while. This happened up north.
There was an oily film on the rear bottom of the gas tank has me concerned. I ordered a PPE rear differential cover. Because it has a drain plug and a fill plug. It has not arrived yet. And I have a lube locker gasket for it.
I cleaned away the oil residue on the rear of the gasoline tank.
Is it possible that the drive shaft seal could leak where it connects to the rear differential? Or could it be something else that I’m missing? I was wondering if that 5 gallon bucket of joint compound hit something. To the best of my knowledge. I have no leaks in the system. I did the rear differential fluid about 2 1/2 years ago. But that’s with the factory differential pan with a rubber plug. I’ll check the fluid level tomorrow.
Thanks for any helpful advice!
