I go to the dealer because I have the Maxxcare Lifetime warranty, and I want all service records recorded. So yes, I'm saying the dealer put in an oil that I'm betting was NOT Mobil 1, and there was a drastic drop-off in oil pressure that went away when I had the oil changed with Mobil 1 the next time.
You're calling me a liar or a fool, and frankly, I'm getting tired of it. I know how my truck runs, I check all things over before and after the dealer services anything to see if anything looks missing or out of place, and I keep an eye on all levels and pressures, trusting that the sensors in the truck work because I just don't have time to install analog ones.
I'm an engineer, I build machines and troubleshoot hydraulic-related systems all the time (which is exactly what our engines have). The type of oil being changed in a system can and will alter the steady-state properties of the system. And when the only things that have been changed are the oil and the filter, and the filter is the exact same one they've been using since the first oil change, then it stands to reason by process of elimination that whatever oil was put in is the contributing factor.
