Brian N
When I was changing the oil in my wifes '11 Ram, I noticed that there was oil on the bottom of the oil filter.
At first, I thought that the filter wasn't put on correctly last oil change.
Upon looking into it further, I noticed that there is a sensor on the front of the block, above the oil filter that seems to be leaking.
Is this an oil sensor? If so, how hard/easy is it to change out myself? Looks pretty simple.
Thank you.
Thank you.
