On-Board Air for Power Wagon
m25443
Houston
I'm inclined to buy a tank to use as a backup in case my compressor fails. Probably overkill, but.....
olyelr
Kewadin MI
Your talking co2, not just air storage right?
Overkill, maybe, but wtf isn't that what your supposed to do?
hbleconey
San Francisco, CA
6.4 hemi
if you're only using it to air up tires, what would be the benefit of having a tank? I have a dual arb mounted in the engine of my 2012 and I'm looking to do something similar on my 2019 but might be it elsewhere. where is everyone mounting it? I don't want to put it in the bed and I don't have ram boxes so it needs to be in the engine bay or possible interior
Trailmaker
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
My last 2 trucks I bolted to the frame and the 2 I have in my cart now are water tight enough to be submersible as well.
On my PW I’m mounting it under my cover on the side of my tool box to help muffler the sound. And it will supply 2 tanks that will be mounted on the frame rail on each side with an air Chuck on each side as well.
Trailmaker
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Trailmaker
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
olyelr
Kewadin MI
NICE!! I can see using that if you are mounting it in the bed of a truck or somewhere else out in the open. Otherwise, somewhere under cover like the hood/rambox/inner fender/etc I dont really see the point of it. It basically just offers protection, correct?
Hammer757
Virginia Beach, VA
Yeah, I don't think you would need it if putting under the hood/rambox/etc. I was thinking for in the bed, or if using a contour rack system. I'm sure someone might find a creative use for it.
kmrtnsn
Ventura
If you're airing any tires larger than 33", don't waste your time with a single unit compressor. Buy the ARB Twin and the small tank. I have one under the hood of my Jeep and I can refill tires back up to 35-40 PSI at twice the speed or faster than the others on a trail run using singles.
kmrtnsn
Ventura
Oh, and order an S-Pod wiring switch system for it and their ARB harness. It'll make any wiring additions you make plug and play with pre-fused and relayed switches.
