I run Redline 530 just as a pre caution. Cost me about 100 or less with filter, But I do 8-9k intervals and only drive like 10k a year. There is an import car shop like a mile away that sells everything Redline so I just get it there.
Burla, I see you suggested sticking with PUP or whatever you are using if you don't have hemi tick. What if you don't have that, but do have the occasional startup clatter that goes away in seconds (and isn't manifold bolts)? It's either piston slap or lifters just needing that oil pressure they don't have sometimes at first turn. Using PUP now, just not sure it's worth changing things up since it's buttery smooth after the occasional startup sound.
When I bought my vette they wanted mobil 1 but after looking at tests on oil and filters I decided on amsoil,it’s used in my 19 ram-14 glk 250 2.1 diesel-11 Audi A3 2.0 and my Z06 dry sump LS7 as well as my standby B&S vangaurd engine but to be safe against cold starts I do use Archoil 9100 1.2oz per qt.Good morning ! sooo i've spent the last couple hours going through forum pages looking at what kind of oil to get for my truck (2015 ram 1500 5.7 hemi SLT) and i am overwhelmed at what kind of oil to get , ive decided to go with royal purple 20-820 oil filter but lost on what kind of oil to get , is Pennzoil ultra platinum the way to go or redline , etc. any input would be greatly appreciated !!
Thank you !
use amsoil for years best ever for me ! I do change early 2,500 cuz of the bad lifters in the hemi ! so far a fuel injector and new exhaust they replace still going 59,500 on it .Good morning ! sooo i've spent the last couple hours going through forum pages looking at what kind of oil to get for my truck (2015 ram 1500 5.7 hemi SLT) and i am overwhelmed at what kind of oil to get , ive decided to go with royal purple 20-820 oil filter but lost on what kind of oil to get , is Pennzoil ultra platinum the way to go or redline , etc. any input would be greatly appreciated !!
Thank you !
rp filter and amsoil feel the best u join them order it comes to ur door sweet !Oh God! Now what to do?? The Redline talk is all about the Hemi tick. Does Quaker State also reduce or eliminate this? The tick is a result of metal-to-metal, right? It wasn't good in my '66 Fairlane or my '55 T-bird, so why shouldn't this tick issue trump (no, not that Trump!) all other considerations?
CMV157. Great factual and helpful information on this subject. I can share with you how I got my 2018 2500 6.4 to stop its morning first start clatter. Keep in mind, each of these engines are a bit different. 5 PUP 0-40. 1 PUP 5-30. 1 32 oz Lubriderm. Come summer, I may need to change the ratio to 4-2-1 of the same. Fitz
Yes Lubeguard Bio techlubegard?
Thanks everyone for the advise , I think I’m gonna go with the PUP 5w20 and a amsoil filter , would any of you have the correct filter number ? Also if the amsoil filter isn’t needed what about the wixXP filter ? Or if the PUP is not good what do y’all recommend ,
2015 ram 1500 5.7 HEMI
Depending upon whether you bought a synthetic or regular oil change package you're most likely going to get PYB (Pennzoil yellow bottle) which is conventional or PP (Pennzoil Platinum) which is synthetic and a Mopar oil filter.I have the maintenance package from the dealer I bought with the RAM. Does anyone know what oil / filters the dealerships use?
