P0153 O2 Code Issue
pm0084
Virginia
I have been dealing with a P0153 code for about 6 months now. Dealer has replaced the O2 sensor and checked wires. Also has both exhaust manifolds redone with new bolts. Issue keeps popping up about every 150 miles or so, just tired of the dealer not being able to fix this.
I attached some screen shots from my code reader to see if that helps understand what’s happening, I don’t fully understand how to read these graphs.
Ken226
Washington State
6 months is too long for a shop to be unable to figure this out.
It sounds like so far, everyone has assumed that the sensor was wrong and tried diagnosing the sensor and/or the wires.
Spray some starting fluid around the intake and listen for rpm changes. See if there is a vacuum leak.
Perhaps try swapping injectors/coils/ from left bank to right bank.
Pull, inspect and if necessary replace spark plugs.
Since you've tried obvious stuff, it's time to start looking at less obvious stuff.
P
pm0084
Virginia
So I used a small smoke machine to check the intake areas (Used the Brake Booster Line) and nothing showed up. I then used the machine to check the exhaust, I found a pretty good leak where the Y connects to the straight pipe (Looks like the clamp rusted off) However not sure this is a problem since it is after the cats and O2 sensors.
Ken226
Washington State
It may or may not be your problem,
But it definitely CAN be a problem. Especially that close to the cats and o2 sensors. There are plenty of conditions in a normally operating engine that can draw outside air in through an exhaust leak and effect the nearby oxygen sensors. Especially if it is a big leak.
For example, during engine braking. The throttle body blade is closed but the engine is spinning kinda fast, this will create high vacuum in the intake system, so during the portion of the otto cycle when the piston has just finished ascending the exhaust stroke, both the intake and exhaust valve are open at the same time (valve overlap), and the high intake manifold vacuum allows exhaust gas to be drawn back into the cylinder/intake. The sudden change from + to - pressure in the y pipe can draw outside air in through a leak, which will mix with exhaust and read lean.
Fix it then test drive.
Even if that doesn't solve your problem, you will have factored out a relevant variable. If you leave things broken all over your truck, they will add up to create problems.
If the problem still persists after fixing ALL exhaust leaks, swap coils and injectors to the other bank. Inspect the spark plugs and either swap banks, or replace them.
P
pm0084
Virginia
So just an update on where things stand. At this point no leaks have been found, and swapping to a new O2 did not fix the issue. No other issues found with injectors or spark side of things either. After a few days of testing, the dealer is replacing the PCM.
RamCares
n/a
n/a
Should you require aid while your vehicle is receiving service, please notify us. From that point, we can take a look into this for answers.
Chris,
Ram Cares
