saltywater63
I pulled a P0344 camshaft position sensor code also an oil pressure out of range code P1524 showing up. I replaced the camshaft position sensor. Check engine light immediately went off. It came back on. Pulled same code. Installed new oil pressure switch. That did not work either. Oil level is good. Oil pressure is running in the 10 psi per 1000 rpm threshold although it does not get over 40 psi at all and gets as low as 15 psi at idle, according to the factory digital gauge. The analog gauge reads slightly below the middle of the spectrum. The most peculiar thing is the traction control light came on when the check engine light first showed up. Traction control light is intermittent now.
Possibly oil pump or trash in oil pick up line?
