P0455 Large EVAP Leak
CycleVIN
Oceanside, CA
I just picked up a 2011 Ram 1500 4.7 RWD from the auction. It has a throttle body spacer, K&N CAI and a high flow muffler. It's throwing a P0455 Large EVAP Leak code. I tried replacing the Fuel Cap with a new Mopar one, and cleared the codes but it came back. After doing some research I was considering replacing the ESIM on the tank or the Purge Valve under the battery. Is there any way to test them before buying new parts? I inspected all lines to make sure they were connected and had no cracks/ holes as well. Thanks in advance, sorry if I forgot anything this is my first thread.
NJMOPAR
Older and faster
ELizabeth, NJ
I'd remove the tb spacer and try clearing again.
Also make sure the air sensor grommet is tight in the CAI tube.
And welcome to the forum.:welcome:
tones2SS
MA
3.3 tt
I don't think it has anything to do with the TB, but I think it's more so your gas tank, gas cap or charcoal canister for your EVAP system.
My 2005 threw this code and I had the gas tank and fuel filter/pump all replaced and it was free of charge because it is an emissions thing.
Good luck!!
apriliaalex
NH
I just made a homemade evap smoke machine and my leak is coming from above the tank. I still can’t pinpoint where but now I know the the tank must be dropped unless anyone has any ideas for me?
It is clearly not a line, connector or the filler tube. I just learned that there are covers over the fuel pump top so I’m guessing that’s where the leak is and why I could not pinpoint exactly where the smoke was coming from.
Daw14
South Florida
There’s rubber elbows on top of tank that split/crack. These are where the emission /fuel hook up on top
RedSRT4Me
Scottsdale, Az
2015 CC Sport
There is a leak detection pump on the top side rear of the tank.
apriliaalex
NH
Unfortunately it’s not that easy of a fix. I replaced the ldp pump easily on the side of the charcoal filter already. The leak is coming from somewhere around the fuel pump locations atop the tank.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Right on. List everything you've tried or fixed to this point? This way if we mention possible fixes and you've already tried it we can move forward to help your problem. :cheers:
Cwils80
Knoxville
From what I've seen and experienced this code can be a PAIN. I had it once and replace the purge solenoid for like $15 and it worked. But from what I've heard it's just a "start replacing parts" type of issue.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
It was for me.
Hanover Fiste
Air Force
NW Florida
2005 SLT, 2018 Sport
I have a similar code on my '05 (P0456, small leak). I've replaced every component in the system except for the hard plastic tubing lines, as they are no longer available. Sometimes the code comes back the next day, sometimes it takes a couple months for it to reappear. I haven't dropped the fuel tank yet; I have a suspicion that's where my problem lies.
tones2SS
MA
3.3 tt
Highly likely.
I had mine done when I owned it A LONG, LONG time ago.
Worked perfectly. Good luck!
