P0521 code came up
cluelessguy
Canada
Engine light came on just as I was pulling into my driveway. Gave me the p0521 code. Checked my idle oil pressure and it was 30 psi and the gauge went up gradually when revving the engine. Is it actually my oil pressure sensor?
Ken226
Washington State
When was your last oil change? If recent, which oil and filter did they use?
C
cluelessguy
Canada
Not sure. Im going tonight to get my oil changed tonight and I'll ask. Hoping the oil change fixes it. Im due for an oil change. Im over the sticker recommendation by 2000 kms and my computer says my oil life is 26%
What's your sticker say for milege between oil changes. Personally ii don't run my hemi's past 8,000 km's between oil changes,as the hemi has oiling issues,and the last thing you want to do is stretch the oil changes out to far
Army
Let us know if this fixes it, is your oil filter spun glass, blend, or paper? If it is paper it could be stiff and bypass not working correctly. See ricks sweet dual filter set up, one filter can easily fail but a dial system prevents that especially if one is a filter with a good bypass. Thanks for posting, if this does fix this should be a sticky.
rockyj69
