PacBrake remote filter install
what would be the case say you broke down on the road and it was towed to the dealer, you could not take it off then you're screwed big time.
If you know it's broke,why would you have it towed to the dealer right away,even if you broke down on the side of the road,it's still easy to remove and spin a factory filter back on. You're operating like it's a days job to remove it,when it should come off in about 5 minutes /10 if you're really slow,lol
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Well first off I don't carry a box load of tools in a new truck and if it is broken down, what are you going to do go all the way home and go back with tools before getting it towed. not practical what you are saying.
3 wrenches are gonna remove it bud,i'm not sure why you think you need a boatload of tools to unbolt 2 bolts and remove 2 lines.There's 2 bolts that bolt it to the frame that are the same size,so that's 2 wrenches,there's 2 lines to remove,that are the same size,that's 1 more wrench.You sure like to make things difficult don't you,lol.You better hand in your man card if you can't get it off in 10 minutes and spin a filter back onto the factory nipple.3 wrenches and a filter will easily fit under the seat. For you i might reconmend not doing the relocation kit though,as it might be out of your league ,seeing as how you think it's an impossible job to remove it :Big Laugh:
madtrucker2016
I like your teaching me how to take it off, but if I put it on you think then I would be able to take it off. OK so I will carry all the tools in my pocket for when my truck takes a crap on the side of the highway, then I will crawl under the truck to disassemble the filter re-locator and put it back to OEM, after that I will call a tow truck to get my new truck off the highway.
madtrucker2016
you forgot the wire cutters to cut the tie wraps.
Why do you put tie wraps on ?
I don't,it was the other guy who is putting zipties on.You quoted the wrong post,i just told him a pocket knife would cut whatever zipties he's used,instead of a set of side cutters.The only thing i use zipties on,on my dual filter set-up,is to hold convoluted hose covering on the hoses,where-ever they might touch or rub something,but they don't have to be removed to remove the kit,as they're only attaching the hose covering to each individual hose.
Bob Horowski
FLORIDA
THE SKY IS FALLING, THE SKY IS FALLING! Who verified your warranty will be nullified with this installation?
ramffml
ramforum
Any mod you make to the engine can be used to deny warranty, probably depends on dealer somewhat and what exactly happened to the engine. Even if you feel Ram is in the wrong, good luck fighting them on it. Lawyers don't work for free.
Rgesse
