TRQ Wheel Bearing Hub experience?
kad
Hudson Valley, NY
5.7L HEMI
Anyone (who doesn't work for them) have any experience, good or bad, with the TRQ brand wheel bearing hub assemblies that 1AAuto.com sells?
-K
Jeepwalker
WI
2012 Reg Cab, 4x4
I haven't used TRQ. Are you looking to buy? Pretty sure for the price they're an import product. They'll probably last you a little while, It's hard to say. I think it's safe to say they won't last as long as an OEM ..but again, hard to say. Depends how long you plan to keep your pickup. If you're running oversized tires, or do much off-roading, I would shy away from the imports and go with a USA/Mexico made Mopar.
I rarely buy import wheel/hub assemblies after having a couple interesting experiences, noise, quality issues. But my brother buys cheap stuff all the time ..LOL. The last import hub I bought from OReilly's for my Hummer had .005" deflection at the hubface out of the box!! LOL. The only reason I took a chance on it (against my better judgement) was I wanted to use the tk for vacation. Luckily I checked it in the vise. Had I installed it, the rotor would have been WAY out of spec ...wobbling all over the place. I took it back and ordered an OEM Delco ...which was perfect and made in USA. But it was 80% more expensive (my Hummer has 33's on it too)
If you buy the TRQ, I would definitely put a dial indicator on it prior to install, to ensure it at least runs 'true' before you install it. If it doesn't it's a POS ...send it back right away. A Moog is like $118, SKF $133 (RockAuto.com). I suspect the Moog is an import too, but they have a known track record of a certain level of quality control. I read on RamForumz that SKF was the OEM supplier for Rams (according to someone who did some digging), but the $133 SKF unit might be a lower-graded product, or import (??). RockAuto sell a ACDelco which is pretty expensive. I wonder if it's and OEM quality product? That's the problem these days ...ya just don't know. Funny I don't see any Mopars on RockAuto right now. I guess between the four hubs discussed, I'd buy the SKF or ACDelco myself.....
If your bearings just started making noise, you should be able to add some grease through the ABS hole (remove ABS sensor, squirt some grease with syringe or grease needle, replace sensor). But best to replace the whole assembly.
Jeepwalker
WI
2012 Reg Cab, 4x4
Actually, I looked up and dropped the Mopar hub/wheel assembly part number into RockAuto's website 68267298AD, and I was able to drop it into my cart, $158. Seems to be in stock. For $58 more than the TRQ, that's the one I'd buy ..if it were my pickup. Should be OEM quality. Low risk. (plz verify fitment)
Burn2k12Ram
Reno, Nevada
I agree with @Jeepwalker here as I have had a bad experience with non-OEM hub assembly before. This is one of those parts you do not cheap out on. You may get lucky but most likely you will be doing the job again sooner than later.
PoMansRam
East Aurora NY
With bearing assemblies you never know what's actually going to be in the box. You could pay up for a brand name and get Chinesium or get one from Napa and find it's an OEM. Best you can do is maybe not buy the least expensive mail-order part and get to it.
Jeepwalker
WI
2012 Reg Cab, 4x4
Those look like some pretty nice A-arms! Replaceable ball joints too. Who makes them? Blue wheel studs, kind of cool ...are your nuts blue too? I mean for the wheels?
EdGs
FL
Just a couple monghs ago, I got the same OE hubs from RockAuto. That price is a full $100 less than my local dealer quoted me.
While the RockAuto price might be a little higher than aftermarket hubs, it's definately worth it for piece of mind, IMO.
DaRam808
Hilo, HI
3.6L V6 24V VVT Engine
I purchased a set of TRQ bearings (not for our Ram), because I couldn't afford the OEMs (way too much for my budget). A year after installation, a DTC code popped up, and the scanner indicated that the attached ABS unit on one of the bearing had failed. Because it came with a limited, lifetime warranty from 1A Auto, they sent me another set to replace that one defective unit (they were sold in pairs). The only problem was because I live in Hawaii, it took a little longer to arrive, but I did get them. The TRQs were affordable and made well for my budget, my problem is it does take a little longer to receive items in Hawaii, since we're in the middle of the Pacific.
Jeepwalker
WI
2012 Reg Cab, 4x4
I don't have any experience with TRQ personally. Let us know how they work out ...long-term. What really matters is how they hold up in 5-10 yrs.
Given the amt of work it is to replace bearing/hubs, and how much is a guy saving buying the cheapies .....the cost of half a tank of gasoline? I would personally only buy the better well-known bearing brands like, Timken, SKF or Schaffler. TRQ is no-name import. Not saying they're not good, but seems risky to me. Sure would hate to have to spend a day redoing them in a couple yrs.
I just put a pr of Schaffler's on my Ram two weeks ago. $125/ea, RockAuto. Their construction looked great and had zero run-out at the flange when bench-tested by a dial indicator. FWIW, I bought an OReilly Auto bearing/hub a couple yrs ago and it came with a pre-warped flange out of the box...lol. Something like .003". You'd never get a rotor to run even close to 'true' on that. I marked it 'Defective' with a paint marker and took it back. But I bet dollars to doughnuts they cleaned it off and sold it to the next guy... :oops:
walleyefey96
