Passenger Window Gets Stuck Rolling Up
GreenClassic
Las Vegas, NV
2015 Big Horn CC
The passenger window on my 2015 1500 gets stuck about halfway while trying to roll it up. Auto will actually make it roll back down, but if I hold the button it will stop but not roll back down. If I hold it and it stops, I then have to take my finger off the switch. Then I have to pull on the switch again to make it go all the way up. What can I do to fix this?
autokraftgt
Hemi 6.1
There's a few things you could check, but jeez...being a 2015, I don't know if my suggestions apply. Behind each door panel, there's a harness that controls all electronics...check to make sure the harness is fastened together correctly. OR, if it was me....take it to the dealer and have them fix it....being brandnew, it should be working like a charm
GreenClassic
GreenClassic
Las Vegas, NV
2015 Big Horn CC
Dealer has the truck to try and figure it out (and I'm stuck with a Nissan Altima loaner, lol).
GreenClassic
GreenClassic
Las Vegas, NV
2015 Big Horn CC
Well, I got the truck back. They said it just needed to be recalibrated. So it works correctly now, yay!
