Thanks.
That's bothersome. I guess I made a mistake by assuming a 2500 could do at least 3k.
I guess I just paid a ton for a 1500.
Thanks.
Thanks.
Yes, you essentially have a 1 ton pickup/drivetrain with heavy half ton suspension.
Add some bags if you tow heavy or put a lot of weight in the bed. Heres a writeup I did when I put them under mine....
http://forum.powerwagonregistry.org/viewtopic.php?f=45&t=4732
The Airlifter 5k brings my payload up to 5k?!
I don't need 5k, but I'll take more than 1600. Looks like a fairly easy install...
It's not going to give you a 5K payload but will increase it considerably<as the Payload Police gasp>. Look at the VIN tag in your driver door for the GAWR and GVWR, those are the numbers you don't really exceed. Your PowerWagon is much more capable than a 1/2 ton.The Airlifter 5k brings my payload up to 5k?!
The only thing the yellow payload sticker is good for, is putting over the mouth of the payload police...lolDepends on how you look at it. If you are the payload police, then no. My ‘17 half ton big horn has more payload than my ‘16 power wagon laramie.
Except the VIN is on it...lolIf it’s the sticker your worried about, PM me and I will hook you up. Own my next trip to the parts yard I will collect a few off some trucks. Want a sticker of a 3500? No problem.![]()
Don’t forget new bracelets too.$3.99 tin snips can fix that. An orange jumpsuit is included for free with usage.
https://www.harborfreight.com/straight-cut-aviation-snips-39611.html
