PCM Part# & Gear's question?
Darkflow
Odessa, TX
Im ready to order the DiabloSport Trinity from HemiFever.
So my questions are,
1. How do i tell what gear's my truck has?
2. Is the PCM Part# start with a P?
There's nothing on the box but there is a tag on a set of wires next to it. Im guessing that would probably be it.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
You can request your build sheet from the dealership or Chrysler customer care. That will tell you the factory gears installed at assembly. Sean should be able to point you to the PCM Number on the module.
Darkflow
Darkflow
Odessa, TX
Dang, i was hoping to atleast get it ordered by tonight. I just requested the build sheet for the truck.
As far as HemiFever goes, how quick does he ship after he's set the tunes?
TXKID
Houston, TX
The gear ratio with be printed on a sticker on the front transfer case if you have a 4x4 or near the rear axle. Just climb under there and you should be able to spot it
craigsez
Novascotia,Canada
You can also go to a dodge dealer and give them your vin and they can give you a copy in a cpl minutes....
I needed my ecu # as well but its recorded into my trinity shortly after i plugged it in the 1st time..
